Cam selection help - Budget 400 sbc build
Old Nov 30, 2010 | 09:44 AM
JimNut's Avatar
Car: 88 Camaro
Engine: 400 sbc
Axle/Gears: 9 bolt
Hey everyone! New to the forum but not the sport
I'm currently finishing up a mild 400 sbc build and having some trouble deciding on which cam to go with. Specs on the engine are:
- 400 bored .060 over (412 ci)
- 10.5:1 compression
- World Product SR Torquer heads (76cc, 2.02 / 1.60's) (not the greatest heads I know but its what I have and money is kind of tight)
- Edelbrock Performer dual plane intake
- Holley 750cfm Vacuum Secondary's
I have a built TH350 trans that I will be using and the car has 3:23 (I believe but havent verified yet) gears. Currently don't have a stall but will purchase one that best matches the cam.
My Camaro will be on the street 95% of the time with MAYBE one or two track visits a year so it has to be street friendly. Lately I have been looking at the Comp Camps XE274H and have heard some decent things but need to know if I should go bigger or smaller.
XE274 specs are here
http://www.compcams.com/Company/CC/c...x?csid=87&sb=2
Any insight would be greatly appreciated! Thanks
Old Nov 30, 2010 | 10:15 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: Cam selection help - Budget 400 sbc build
Thats a lot of camshaft to live with daily.I'd lean more towards the XE268,and ditch the performer in favor of an RPM or a Weiand Stealth.That should put you in the 360-375hp range,which is about as far as I'd dare push a .060 400 anyways.Be prepared for cooling challenges at that bore,as well.
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
camaro71633
Sep 1, 2015 10:24 AM
LT1Formula
Aug 20, 2015 09:36 PM
Cameeeero
Aug 20, 2015 03:06 AM
