Cam choice and worn out cam
Old Dec 3, 2010 | 04:31 PM
VandykeT/A's Avatar
Ok so after we rebuilt my 305 in my 86 it had a miss and popping in it. We changed plugs, wires, cap, coil, distributors,3 carbs, and it still runs the same. So we took the intake off and found one of the lifters had a wear pattern all the way across and the others just had the little circles on the bottom so im gonna say i tightend the lifters to tight and owre out the cam. Now my question is for a DD would the xe268 be good or would you guys recommend somthing else while its apart. Thanks
Old Dec 3, 2010 | 06:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cam choice and worn out cam
The XE268 is a good street cam, if your heads can take the lift.
You're doing a complete rebuild to clean the metal debris out, right?
Old Dec 4, 2010 | 01:49 PM
VandykeT/A's Avatar
We all ready rebuilt the engine and put it back. Thats how we ended up wearing the cam out. Adjusted the valves to tight when we put the engine back together. And i've got the valve springs for the cam i just haven't installed them yet. It wno't hurt to run the engine with the old valve springs for a little while until I get to change them as long as i take it easy on it will it ? Its got 416s on it now i think.
Old Dec 4, 2010 | 03:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't matter if the engine was rebuilt before you wiped out the cam or not. It's trash now, and it needs to come back apart.
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
Stryker412
Sep 7, 2015 09:11 AM
Strick1
Sep 4, 2015 07:11 AM
