need some help car somtimes wont idle
Old Dec 6, 2010 | 08:19 PM
joey 350 LT4's Avatar
Car: 1991 1le 5.7 6 speed
ok so as its getting colder out i have been having idle issues. 1st that car is modified along with a tune and sometimes hunts for idle and has been doing so since i have owned the car. now the issue when u start the car it starts then dies. i have in the past few days been able to simetimes start it cold or hot and its fine some times i have to let it get warm then it will idle.. so i checked my tps volts there a little high but have been so for over a year .95 closed 4.50 WOT. i also replaced my IAC now heres my first question it was far out when i put it in but gave no resistance when i tightened it is that wrong or damanging or is it ok to do? i beleive i followed the instrouctions on here pretty well. but i am going to try to reset it again 2moro. my second questions is what else can cause this? i can affored to replace everything or have the time im hopeing someone just hits me with the right solution. also car dose have a vac gauge and i dont see according to the gauge a vacume leak thanks guys!
Old Dec 7, 2010 | 10:04 AM
re: need some help car somtimes wont idle
update for any one intrested! i checked the volts one the IAC and even pulled it back out and it is working fine.. car still will not idle i thought it could be my dakota box for my 6 speed and it is sending a signal as well. any else having same issues?
bump
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
