What oil are you guys running? What engine/mods? Lucas?
Old Dec 9, 2010 | 11:34 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Just curious as to what oil you guys are running out there. The climate you're in, and also if you have any modifications done to your car. Trying to get an idea of what I should be running. Also, what do you guys think about that Lucas oil additive?
Old Dec 9, 2010 | 11:43 AM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Re: What oil are you guys running? What engine/mods? Lucas?
Penns synthetic
Old Dec 9, 2010 | 02:01 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
No need for additives, almost any oil will work for you unless you get too thick.
Highly modded 6" rod 350 large heads, solid roller 7500 redline
Mobil 1 10/30 syn
Old Dec 9, 2010 | 02:19 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
87 IROC 5.7
Castrol GTX 10/30
Comp cams xtreme energy cam, trick flow heads
Old Dec 9, 2010 | 03:11 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
VR1 20-50
Old Dec 18, 2010 | 10:56 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Royal Purple 5w-30. Pretty much stock.
Old Dec 18, 2010 | 11:53 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Basically stock 350 with 305 heads, flat-tappet cam.
Running Pennzoil 5w-30 with STP's ZDDP additive. Probably switching to 10W-30 or 40 next summer since it's a summer-only car.
bryan623
Mar 22, 2021 06:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
matthew911
Aug 12, 2015 09:38 AM
gwade12
Aug 8, 2015 08:17 AM
