interested in doing new camshaft. not sure what to go with.
Old Dec 10, 2010 | 03:46 AM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
Transmission: 5 speed
im driving an 86' iroc and with that year the cam was replaced in order to gain more torque but unfortunately lost horsepower. this has a 305 tpi. i already have edlebrock headers and flowmaster exhaust. i dont really know where to start when choosing a camshaft. i still want to have a half decent idol but obviously a bit of a grunt to it. what do you guys run or find has worked best for you? any input or experience would be really appreciated
Old Dec 10, 2010 | 08:13 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: interested in doing new camshaft. not sure what to go with.
If it gained more torque over stock then it probably gained hp too. Cant make one without the other.
Old Dec 10, 2010 | 10:22 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Need to know if it's a roller block or not. You've done headers and exhaust. Next is heads and cam. If it's not a roller block, you'll need to replace the lifters as well. Also, I would replace the old springs as well. I've heard some good things about this cam:
Lunati Voodo Cam and lifter Kit
There are also Comp Cam camshaft's that are comparable to this is you'd prefer.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mattcanty
Oct 12, 2015 11:08 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
6998poncho
Sep 25, 2015 02:56 PM
