To delete or not to delete? Help!
Old Dec 10, 2010 | 09:27 PM
Rons91Bird's Avatar
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
I'm getting that nagging code 32 ( EGR ) I have read alot here about the EGR, many informative posts and lots of opinions. My 90' GTA idles rough ( SES on) The EGR valve is relativley new. I don't see any issues with vacuum hoses.
I can get on it hard for a bit and the Light will go off and the idle is smooth. But if i sit too long the light will come back on and begins to idle rough again or if i shut it down and restart the light will come back on and idle will be rough again. I can check the EGR Solenoid and valve again, or i can just burn a chip and delete it.
I have no air, ( Headers, a/c and smog delete pulleys ) o2 sensor is new but is not the heated type, and not sure what role that could play in the problem.
Any suggestions, opinions ( I like those ) would be greatly appreciated.
I don't mind keeping the EGR if i could get it all ironed out!
Thanks!
Old Dec 10, 2010 | 10:25 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
Re: To delete or not to delete? Help!
You can burn a chip and delete it, but you shouldnt have that problem from an egr. i know alot of people just make a block off plate for them and it works fine
Old Dec 11, 2010 | 12:58 AM
Rons91Bird's Avatar
The reason i was thinking the EGR was causing the rough idle problem on and off, is because the ses being on and the code 32.
Anyone have any ideas. What to check? I did find a split wire boot, going to replace wires, that would cause a possible missfire though right?
Old Jan 4, 2011 | 08:55 PM
Car: 1982 trans am
Axle/Gears: 3.08
a split boot can and most usually does cause a missfire, even low grade wires can cause it
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
