A loud thud when stopped recently.
Old Dec 12, 2010 | 02:26 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
For about the last 2 weeks now, about once every 2 days I'll pull up to a stop light and stop. As I'm sitting there, I hear a loud "THUD" that sounds like it might be coming from the rear end. However, nothing happens. I don't move at all, my car continues to run as usual, and the break work fine. I'm wondering if it's maybe the motor doing something since recently we have found a crack in the engine block where coolant is leaking out of it.
Old Dec 12, 2010 | 03:06 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: A loud thud when stopped recently.
Hello Dartht33bagger!!
When was the last time that you changed your diff fluid???
The noise that you are hearing is the clutch cones releasing from torque lock.........change your diff fluid, and it should go away!!
Don't forget to add the posi-lube additive, this will help to prevent this from happening again!!
P.S. How do I know this??? It's happened to me!!
The additive helps to remove "varnish" that starts to stick the cones together from heat soak when your at a stop, when the cones release the torque lock, that's the thud that you hear!!
Old Dec 12, 2010 | 04:32 PM
Car: 1991 Z28
Thanks for the fast response! Should be an easy fix then!
One more question, do I still want to add the posi-lube even if I only have the stock limited slip rear end?
Old Dec 12, 2010 | 04:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
JamesC
Old Dec 14, 2010 | 12:40 PM
Yes........like JamesC said!!
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
