high idle.
Old Dec 16, 2010 | 06:07 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Transmission: Borg Warner T-5
Axle/Gears: Borg Warner 9 bolt - 3.70 posi
high idle.
just need a second opinion. I've had problems with the IAC before, i can pretty well recognize the symptoms. On a cold start, the car won't idle, then once it warms up it will idle at 1000-1500 rpm until i sit a a stop for at least 5 seconds. The IAC that's in there is one that was pulled out of a TBI and has a lighter spring than the normal TPI, thinking it's just worn out. other opinions welcome.
Old Dec 16, 2010 | 10:07 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Re: high idle.
Nobody?
Mark_ZZ3
May 24, 2018 01:02 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
