maf help please
Old Dec 18, 2010 | 07:31 PM
infared337's Avatar
maf help please
89 gta 305tpi..heres the question..my car was throwing codes for mass burnoff relay..i replaced the relay, the mas itself, the connectors and everything associated with it..also have a new ecm at the same time..
the car idles fine but there is no power.. if i disconnect the mass when the car is running the car shuts off..what does this mean? ive had issues with the car all new power supplies, mass, relays,ground wiring and ecm..still same problem HELP MEE!!!!
Old Dec 18, 2010 | 08:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: maf help please
Sounds like the MAF is underreporting. When you disconnect it, the ECM thinks there is no airflow, and very little fuel is delivered to the engine.
Ideally, you should scan the ECM to see what is going on. That can tell you if the MAF is underreporting. The only other way to tell is to backprobe it with a DVM, and see what the voltage is when the engine is running, but thats even harder.
Who made the MAF that you bought as a replacement? Its possible that its output calibration isnt the same as teh stock one.
Old Dec 19, 2010 | 01:57 PM
infared337's Avatar
Re: maf help please
its a delco i also tried it with another one from a friends car and the original one. same results with all of them.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
