i dont know if i should do this??
Old Dec 19, 2010 | 11:27 PM
jll87TA's Avatar
Car: 87 trans am, 82 trans am
Axle/Gears: stock
ok so i have an 87 trans am with the 350 tpi is all stock except for the flow masters. i've been thinking of selling it. the reason i want to sell it is because i want to buy a car that doesn't waste much gas, and the needs money to put on and i don't want to put no more money. the original color is burgendy but it was paint black the paint is ok but if waxed it will shine, the rear spoiler is crack, i have weather strips for doors and hatch still in box, right now it has 20" chrome irocs but i have the original wheels they need new tires. i just put rebuild headlight motors you'll just need the motor module. the interior is ok i has a tear in driver seat dash board is crack and you'll need new headliner. it has 202xxx miles. the engine was rebuild on 6/23/10 and it has 1yr warranty or 1200miles. it only has around 1200miles since rebuild. rebuild was 1600. i still have receipt. tags are up until nov 2011
parts that have been replace:
brake pads
hood struts
battery
center link
idler arm
ball joints
rebuilt headlight motors
passenger headlight assembly
problem i have with the car is the car turned off when i did turns or stop in red light or sometimes i didn't turn on but this didn't always happen and when the car wanted to turn off the rpms drop and the ses was flashing. mechanic replace the ecm because he didn't get no codes after he replace the ecm he replace the maf and it worked but a week or so the problem happen again so he told me to replace the coolant temperature sensor and i did and it worked. then like two weeks ago the car didn't turn on and i put an old ecm i had in the garage and i turn on but when i put it on reverse or drive the rpms were dropping and almost turned off so i keep on doing it until it did turn off so i took it to another mechanic he check it and he said that the maf was bad, i told him this was my second one already! so he check the connection from the maf to relay and from relay to comp and both were good. he say i might have a bad ecm, prom or maf. car still drives but problem may come any time. oh and car is salvage. i still don't now for how much ill sell it. give me a price with irocs rims or original rims
if i miss anything you want to know about the car, let me know, send me email for pics, tell me what part of the car you want me to take a pic of
Old Dec 20, 2010 | 12:01 PM
jll87TA's Avatar
Axle/Gears: stock
Re: i dont know if i should do this??
any1????
Old Dec 20, 2010 | 01:34 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Originally Posted by jll87TA
any1????
Dude, if you're selling it you need to post it in the "Cars for Sale" forum. If you are asking for help with your mechanical problem then say it.
