running slugish?
Old Dec 20, 2010 | 02:51 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
running slugish?
I have an 89 bird, and its running kinda rough. It's a 305 TBI, and on cold start-up it wants to die. It starts to bog out so i give it a little gas to keep it alive. This goes on for about a minute or two, then everything seems ok. But It hesitates under acceleration, and whenever I turn abruptly it seems to lose power and bog out as well, Its really odd. This car used to be bad ***/fast and furious, now it seems to be slow and delerious
Old Dec 20, 2010 | 10:43 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Re: running slugish?
My SES light came on today, so I checked it out and got codes 32 and 54. Can someone help me diagnose these issues, I need this car to run right. Its my only means of transportation. Here are the codes and the possible suspects.
-Barometric pressure (BARO) sensor circuit failure.
OR
-EGR vavle diagnostic switch - closed during engine start-up or open when EGR flow requested by ECM
OR
-EGR/EVRV
#54
-Low fuel pump voltage
OR
-Fuel pump relay
OR
-EGR solenoid No. 2 failure
OR
-Quad-driver Module output failure
OR
-Mixture Control solenoid - Circuit voltage too high
Old Dec 22, 2010 | 03:19 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Realy? No one knows anything about these codes and how to fix 'em?
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
