Ordered this...
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Ordered this...
http://www.jegs.com/i/Mr.+Gasket/720/6238/10002/-1
received this
http://mr-gasket.com/ProductDetails....minselection=2
I screwed up my dipstick tube during a head swap and I've been out of a ride for 7 days waiting on this part. Will the 82-85 dipstick fit my 89 block?
received this
Car: 91 camaro RS
Re: Ordered this...
dont take my word but i dont see why not. i thought the only difference what that the DS was on the other right side on earlier years and left for later.
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
Re: Ordered this...
they have the same part # so you should be good.
also summit says it will work on 82-89.
http://www.summitracing.com/parts/MR...RO&prefilter=1
Car: 1987 Iroc Camaro
Engine: 383 GMPP TPI
Transmission: 5 Speed Manual
Axle/Gears: 10 Bolt 4:10 Eaton Posi Moser Axles
Re: Ordered this...
As long as you know you've got 5 quarts of oil in the pan, this shouldn't have to lay you up until you find a replacement.
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Thirdgen89GTA
Nov 26, 2015 11:04 PM
