Cam selection for 350
Old Dec 25, 2010 | 06:14 PM
dtk132's Avatar
Car: 1986 Camaro
Engine: 350ci 5.7L
Transmission: T-5 Borg Warner
Axle/Gears: 10bolt/ 3.42
Hi everyone,
I am looking into buying a nice camshaft for my camaro. It is an 86' with a 1st gen 350ci engine and 5 speed manual transmission. With an Edelbrock permormer RPM manifold and hedman headers. I am also running 150 shot of nitrous.. Occasionally.. this is a street/strip car. Not a pure nitrous running car.
So i am not sure if i should stay with an actual nitrous cam or a street/strip?
Next.. As most people would want, 1st best performance, 2nd is a nice chopey and cool sound. So what would be my best bet? I am also looking for something affordable so probably a flat tappet cam for now.
Im not to sure about a thumpr cam tho, i cant see that giving my car the best performance, although it does sound nice.
Suggestions?
Old Dec 25, 2010 | 06:50 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: Cam selection for 350
Some more things we need to know first:
What kind of heads (for max lift reasons)?
Is it carbed?
Sorry I cant recommend too much, I mostly just went with the biggest lunati voodoo that i could fit without modding my vortec heads (which was just the second smallest)
Old Dec 25, 2010 | 11:46 PM
dtk132's Avatar
Car: 1986 Camaro
Engine: 350ci 5.7L
Yea they are stock heads for now. I am not driving the car till spring and i should have some nice aluminum AFR heads by then. As well, my carburetor.. its a 4 barrel 600cfm holley. I will look into upgrading larger and better. More into a 670-750.
Old Jan 2, 2011 | 03:23 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You might want to post this in the engine tech section.
Also, you need to tell us which AFR heads you plan on buying and spring height.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
