Vortec Head Swap
Old Dec 28, 2010 | 04:26 PM
fastestbandit's Avatar
Vortec Head Swap
I have a 1984 Trans Am with a dead 305, a good 350 from a 1982 Corvette, and an almost new set of GM Vortec Heads from an unknown year 305. There are no rockers on the Vortec Heads and I would like to put those heads on the 350, and put thatmotor in the Trans Am. I've read that choice of rockers is critical when swapping on Vortec Heads. I don't want to build a screamer, just a nice street car. Can I use the stock GM rockers from either the dead '84 305, or the ;82 Corvette 350, on the Vortec Heads when I bolt them onto the 350. (I have the correct intake manifold.)
Thanks, DickJ
Old Dec 29, 2010 | 09:48 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Vortec Head Swap
uh what casting number are those "vortec" heads? If the casting numbers dont end in 906 or 062 then they arent the good vortec heads. The 305 "vortec" heads are not the same.
vortec heads require self aligning rocker arms.
Old Dec 29, 2010 | 10:45 AM
Stephen's Avatar
Car: 87 GTA
Vortec heads have a unique intake mating surface/pattern, so you would have to get a Vortec-specific intake manifold too.
With your car being a '84, I'm assuming Q-jet carb'd, so the intake is easy for you to get, but adds another thing to buy.
Do they have valve covers already? You'll need new valve covers too, if not.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
