1983 camaro no spark
Old Jan 2, 2011 | 04:23 PM
camarostew's Avatar
I have a 1983 camaro, and I am not getting any thats not getting any spark, I have replaced the spark plugs the wires, the pick up coil the ingtion coil, the distributor cap and rotor. I am out of Ideas of what it could be. I have also replaced the starter and battery.
Old Jan 2, 2011 | 07:15 PM
yellowsnow's Avatar
Re: 1983 camaro no spark
Ignition Control Module
http://www.ehow.com/list_6300728_fau...-symptoms.html
Old Jan 2, 2011 | 07:25 PM
torque_is_good's Avatar
when you first began the troubleshooting, did you test from the coil to see if there was spark there? If there was not, then you of course knew that the distributor, cap, rotor, plugs and spark plug wires were not the culprit.
Did you get any spark from the coil?
Old Jan 4, 2011 | 04:39 AM
camarostew's Avatar
Originally Posted by yellowsnow
I am going to give this a try and see what happens
Old Jan 4, 2011 | 12:39 PM
bigrobwills's Avatar
Car: 87 camaro z28
Axle/Gears: 10 bolt 3.73
i have the same problem with my 87. Ive replaced the cap and rotor. the coil, the ICM, and still no spark
Old Jan 11, 2011 | 04:48 AM
camarostew's Avatar
This worked, there was a spark, but it still won't start, working on it this weekend.
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Aug 22, 2015 08:17 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
