[VIDEO] 1991 Camaro won't start
Old Jan 8, 2011 | 03:10 PM
Krishan's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
So here's the video.
http://www.youtube.com/watch?v=rUD75ah5ZxM
The night before, I just unscrewed the radio + heater control thing, and left it overnight, supposed to work on it today
It's like 30 degrees outside today. Car stopped starting yesterday night-figured it was just a dead battery. Finished charging today, and tried to turn over the engine.
Instead, I got this loud clicking/slapping noise coming from the engine. Could it be the starter? I don't know.
and btw. I'm new. hello forum.
Old Jan 8, 2011 | 03:14 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: [VIDEO] 1991 Camaro won't start
It sounds to me like the battery is toast. It's either that, or the starter, but that seems like dead battery to me...
Old Jan 8, 2011 | 03:25 PM
Krishan's Avatar
Engine: 5.0 305 TPI
Hmm. Alright, I'll try to look into that. I'll charge the battery for longer now. I'll post back if that doesn't work.
Old Jan 8, 2011 | 04:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
dead battery
Old Jan 8, 2011 | 05:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Charging the battery at this point is probably a waste of time. Its really cold out, so the plates are sulfated. Youll need to get a new one if its dead.
Do you have a DVM? Whats the battery voltage when you try to start it?
Old Jan 8, 2011 | 08:00 PM
torque_is_good's Avatar
there are 2 issues
1- that's a classic dead battery and charging won't help
2- your stereo is falling out
Old Jan 9, 2011 | 01:36 PM
Krishan's Avatar
Engine: 5.0 305 TPI
Ah. Time wasted really. Turns out my battery charger is busted. So it's never been charging since i "plugged in". Alternatively, I jump started today and it started up fine with the voltmeter in the dash displaying +13V. Turned it off a few minutes later...and the battery went back to such little charge, the horn wimpered then went silent.
So I guess the real problem here is just a matter of recharging the battery.
Thanks guys, that's one more educated newb in this world.
...was trying to do some work earlier on the temp controls. That explains why it's just 'chillin' out there.
Old Jan 9, 2011 | 01:41 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I was hoping to hear if you got it running today. As for the battery; why did it die in the first place? If it "just died", I'd still suspect a bad battery. If the volts were reading 12-14 when the car was running, then the alternator is most likely ok.
Old Jan 9, 2011 | 01:52 PM
Krishan's Avatar
Engine: 5.0 305 TPI
I'm not sure really...
Well since the battery died, I must've left something on overnight, along with the 20+ degree weather
...how I could have missed that is a mystery.
Old Jan 10, 2011 | 06:58 AM
I'd like to point out that on a forum, when someone says they tried to charge the battery but "no joy" then the assumption made by those trying to help you, for free, was that your charger was good.
I see that comment as if you proved something to the poster who said charging was a waste of time if you had already tried it.
How are we to know that you were either using the charger incorrectly or it was bad????? How were we to know that you hadn't even tried a jump start?????
sheesh, let no good deed go unpunished
Old Jan 10, 2011 | 05:43 PM
Krishan's Avatar
Engine: 5.0 305 TPI
lol! Didn't mean to be ungrateful!
I definitely learned something from all this: the tell tale signs of a dead battery.
Another experience to add to the book.
Next time I'll be more detailed with my problems
By the way, from the video, can anyone judge if I have a 305 or 350? I read a comment from somewhere that the side which the alternator is on (driver vs passenger) determines whether its this or that.
Apparently driver's side = 350. . .
Confirm or bust?
-and I'm not sure I want to go by the VIN on the car.. . even though it says I have a 305.
Old Jan 10, 2011 | 08:04 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
False. You can not tell a 305 from a 350 in fully dressed form from physical appearance. The only way you can tell is the casting numbers located on the back of the driver's side of the block just below the head.
Old Jan 11, 2011 | 06:30 AM
yup
what he said. They look identical
Old Jan 11, 2011 | 06:41 AM
ASHEStoPHOENIX's Avatar
Car: '91 Firebird Formula
Engine: 5.0 305 TPI V8
Transmission: Automatic
Yep. My best guess is the battery. I know this is a Firebird/Camaro forum, but before I traded my 2000 Blazer for my '91 Firebird Formula, the Blazer died. I tried jump starting it with my buddy's van, nothing happened. Spent the $80 on a battery, popped it in, she fired right up.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
