1986 350 Carb
Old Jan 3, 2011 | 10:36 PM
MetallicaWolfe's Avatar
Car: 1986 Berlinetta Camaro
Engine: 350 SWAP
Axle/Gears: Stock
1986 350 Carb
Ok so I'm finally nearing the end of my swap. Well it's swapped just not running. -Brand new Goodwrench crate-
I'm probably going to just put it in the shop for the rest but heres my question.
So I cranked it over the other day without plugs to get oil pressure. Now today I did the same thing then tried to get it in TDC. But when I crank nothing, it tries but no combustion as far as I can tell.
Last my certainly not least; I forget when it started but its making this god awful loud noise when I try to crank it. I'm thinking the oil pump may be dry and that's what I'm hearing? Yesterday when I cranked for oil pressure I would get it up to 20psi but stopped cranking. It then proceeded back to 0 but as far as I remember that's normal. Only did that 2 times that day.
Doesn't sound like grinding but it has a rhythmic sound to it. My only guess is oil pump isn't primed completely? Maybe I wasn't cranking enough I dunno. Again I didn't try cranking it over very much. Most of it came from trying to find top dead center without the plugs.
I hear the regular crank noise but this noise drowns it out so...XD
Old Jan 4, 2011 | 03:17 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 1986 350 Carb
maybe the starter is bad or not shimmed correctly
Old Jan 4, 2011 | 07:10 PM
Engine: 350 SWAP
Axle/Gears: Stock
Re: 1986 350 Carb
Oh the problem was my battery and a slow crank, almost got her started today so thanks anyway!
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
