91 z28, odd starting problem
Old Jan 6, 2011 | 02:17 AM
Gabaloo's Avatar
auto trans, 305 tpi
this happened at my work last night, i drive about 10 miles on the freeway to work, and park in a closed structure.
all the lights worked when i put the key in, fans started any everything. but it didnt crank at all, the gauges all went up, everything happened normally except for the car actually starting. not even a little crank or anything, just silence. i try this a few times and decide to walk to the store. about a 15 minutes interval, i get back, smoke a cig, and the car starts right up....
what kind of insane problem is this? it does smoke a little on start up, due to leaky valve guides i beleive, could this have an effect on the start up?
and help is appreciated.
-greg
Old Jan 6, 2011 | 10:52 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: 91 z28, odd starting problem
Does the security light flash when it won't start? If so then it is something to do with your vats system and it didn't like your key. If not then I would be guessing ignition system. Maybe a bad starter solenoid or an ignition switch.
Old Jan 7, 2011 | 04:24 PM
Gabaloo's Avatar
i dont think so about the security light? this has only happned twice. maybe ill replace the starter stuff to see what happens
Old Jan 7, 2011 | 05:02 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I would suggest looking into the VATS security system before you throw any parts at this. New starter and/or ignition switch will do you no good if the VATS module is bad. It is most likely just the contacts in the ignition cylinder. They become stuck and fail to make contact with the resistor pellet in the key. Try wiggling the key in the cylinder to see if you can bump them loose.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
