Fuel Line Replacement (Fuel Pump/Sending Unit Question)
Old Jan 7, 2011 | 09:25 PM
notoriouscamaro's Avatar
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
I'm replacing the feed and return lines on my 92 RS 305 TBI. They are rotted out and need to replace them. I suppose I am changing the line at the TBI unit all the way to the tank.
I want to replace the fuel pump and fuel strainer. (What brand is good? Should I buy it from autozone or napa?) Also, my fuel sending unit is working (The gas gauge works) so do I have to replace that?
What exactly do I need for the fuel line replacement? I am picking up the coated line, fuel pump, fuel tank gasket. Do I need rubber hoses?
Any precautions before I drop the rear end and tank? I should probably buy new nuts and bolts because they are rusted to hell.
Sorry if there are so many questions on this. Any help would be appreciated.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
AkDrifted
Aug 17, 2015 07:45 PM
