Cooling Fan Problem
Old Jan 10, 2011 | 11:22 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Cooling Fan Problem
Car is a 92 RS with the 305 tbi. It has the single fan setup. The fan does not turn on when it is in diagnostic modee checking for codes. The fan does work while the AC is engaged. What could the problem be?
Old Jan 10, 2011 | 12:56 PM
Jcase350's Avatar
Car: 90 Camaro Iroc-z
Re: Cooling Fan Problem
Are you getting power to the fan?
Old Jan 10, 2011 | 01:00 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
I believe I am getting power to the fan since it turns on when I turn the ac on.
Old Jan 10, 2011 | 01:50 PM
Jcase350's Avatar
Check to see if it's sending power to the fan when it's supposed to be on.
Old Jan 10, 2011 | 02:13 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
My wiring diagrams for the 92RS with TBI do not show the fan being PCM controlled. Therefore, don't expect the fan to come on when in diagnostic mode. The fan is controlled by the fan relay which is activated 3 differen ways.
First the relay is activated by the HVAC control switch. The fact that your fan runs when AC is on tells us that the relay and fan are okay. Second, it is activated by a temperature switch located in the pass side cyl head, below and between 6&8 spark plugs. There is a green and white wire going to it. Grounding this wire with the key on should turn on the fan. If not, check and repair the wire. If the fan comes on with this wire grounded but does not come on when the engine is hot, replace the temp switch.
Third, the relay is activated by the AC pressure switch(on 1991 or early production 92). This would be redundant to the AC control switch and not important since the fan runs whenever AC is on.
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
JHX
Aug 29, 2015 02:30 PM
Leggman1
Aug 6, 2015 04:15 AM
