Crane Cams powermax 109821, is it a good cam?
Old Jan 13, 2011 | 06:01 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Hows it going? When I bought my GTA in '07, the PO gave me the receipt and spec sheet of the cam the car had in it. I ended up losing it and just the other day found it (thought I had lost it for good). Anyway, its a Crane Cams Powermax 109821 and the lift is .488"/.509", Duration is 276º
intake/284º exhaust. Would this be considered a mild cam? Anyone else running it? I'd just like to know if its a good cam overall. Thanks in advance.
Later,
Phoenix
Old Jan 13, 2011 | 08:29 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Crane Cams powermax 109821, is it a good cam?
It is a mild cam. You can see the specs at http://www.summitracing.com/parts/CRN-109821/
Whether it's a "good" cam really depends on what you're wanting out of your motor. I'm not a cam guru but, overall, I would say its a decent cam for a near-stock L98.
Hope this helps.
Old Jan 13, 2011 | 05:06 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Cool thanks for the input formula_novice. I figured it was a mild cam since it hardly has a lopey idle. As far as what I would want out of my motor, I'm shooting for about 400+ HP (450 HP tops). I'm pretty sure I'd have to step up to a beefier cam as well as other supporting mods. The fact that it has less than 1k miles allows me plenty of 'time' to achieve this.
Later,
Phoenix
Old Jan 15, 2011 | 04:25 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Its a good mild moderate street cam. A step up for a TPI motor.
A good choice for what you have. If you want 450+ hp supercharge it.
Old Jan 17, 2011 | 05:21 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Good info F-BIRD'88 thanks. I have put some thought into what type of forced induction I'd like on my car. A twin turbo install was in my future plans but if a supercharger will get me to that range of HP then I'd rather go with that. You can't go wrong with the sweet sound of a supercharger screaming down the street when you mash the gas; well for me anyway. I do plan on throwing on some AFR 195's and some other mods as well. Thanks for the info man.
Later,
Phoenix
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
Fronzizzle
Aug 9, 2015 01:15 PM
