97-98 LS1 rebuild kit sold @ summit???
Old Jan 16, 2011 | 01:07 AM
blakecharles's Avatar
Has anyone tried this kit?
I don't know much about pistons, are these an OEM replacement? Will anything else be required? This kit is $600usd, can't find anything cheaper then that w/ pistons. I have a 98 LS1 btw..
http://www.summitracing.com/parts/FE...ComboContents/
Sealed Power ZBK6081000 - Sealed Power Engine Kits & Rotating Assemblies
all below included
Sealed Power Z1888M - Federal Mogul Cam Bearings
Cam Bearings, Steel Backed Babbitt/Copper Lead Alloy, Chevy 1997-2004, 5.7L LS1, Kit
Sealed Power Z7298MA - Federal Mogul Direct Replacement Series Main Bearings
Main Bearings, Standard Size, Bi Metal, Chevy, GMC/Pontiac, 4.8, 5.3, 5.7, 6.0L, Set of 5
Sealed Power F82555A - Federal Mogul A-Series Rod Bearings
Rod Bearings, Performance, Standard Size, Bi Metal, Chevy, Small Block, Set of 8
Sealed Power Z2601909 - Sealed Power Engine Gaskets & Seals
Gasket Kit
Sealed Power ZE938K - Sealed Power Performance Piston Ring Sets
Piston Rings, Moly, 3.897 in. Bore, 1.5mm, 1.5mm, 3.0mm Thickness, 8-Cylinder, Set
Sealed Power ZH868CP - Speed-Pro Hypereutectic Pistons
Cast Piston
Old Jan 16, 2011 | 12:32 PM
vangogh4560's Avatar
Car: 1987 camaro lt
Engine: soon 383
Re: 97-98 LS1 rebuild kit sold @ summit???
all below included
Gasket Kit
Cast Piston
GM uses speed pro-Hypereutectic Pistons is some of there crate engines.. the GM HT 383 i had cam from GM with them looks like a good kit
Old Jan 16, 2011 | 01:06 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I don't know anything about that one, but I generally stay away from kits. They are normally a bargain collection of parts that may or may not be optimal for what you're building. Have you already determined that you need new pistons?
I'm not really saying yay or nay, just throwing that out there.
Old Jan 16, 2011 | 03:32 PM
No, I have not determined if new pistons are needed... but they do come in the kit and I planned to install everything else. This is a stock rebuild (I have to pass smog in cali so I cannot do much).
From what I can see the kit looks good but I don't know if it comes with the correct pistons. I hate to be a test subject, but it's what's in my budget and has all the parts I need (think I will buy a new oil pump later).
Old Jan 16, 2011 | 03:33 PM
I belive everything will work fine, I just don't know about the pistons. It's comes with 8 of these (will they work for a 1998 f-body dropout):
Brand
Sealed PowerManufacturer's Part Number
ZH868CPPart Type
PistonsProduct Line
Speed-Pro Hypereutectic PistonsSummit Racing Part Number
SLP-H868CPUPC
614046630130
Bore (in)
3.898 in.Bore (mm)
99.000mmPiston Style
Flat top, with no valve reliefsPiston Material
Hypereutectic aluminumCompression Distance (in)
1.328 in.Wrist Pin Style
Press-fitPin Diameter (in)
0.945 in.Piston Ring Thickness
1.50mm x 1.50mm x 3.00mmQuantity
Sold individually.Notes
DurOshield® coated piston skirt.Calculator
Compression Calculator Tool
Stroker Combinations
Old Jan 16, 2011 | 03:41 PM
Car: 1987 camaro lt
Engine: soon 383
Brand
ZH868CPPart Type
PistonsProduct Line
SLP-H868CPUPC
614046630130
Bore (in)
3.898 in.Bore (mm)
call up the summit tech line they will tell you every thing you need to know about it
Old Jan 16, 2011 | 09:38 PM
can anyone tell me if the 98 LS1 uses a flat or round top piston?
Old Jan 16, 2011 | 09:43 PM
Car: 1987 camaro lt
Engine: soon 383
Piston Specifications Material
Cast Aluminum Description
Strutless, flat top. Compression Ht.
1.34” Weight
15.5 oz.
Old Jan 16, 2011 | 09:53 PM
Car: 1987 camaro lt
Engine: soon 383
Old Jan 18, 2011 | 02:50 AM
thanx, that's what I needed to know. Looks like the kit may be just what I needed.
Old Jan 18, 2011 | 03:05 PM
Pocket's Avatar
Car: 91 Trans Am
LS1s are flat tops. Only 99-06 5.3's and LQ4's are dish pistons from the factory
I wouldnt bother with that overhaul kit. Half the stuff in it should be a replace as needed like the pistons and cam bearings. It leaves out alot of the other necessaries like the TTY rod/head bolts. The gasket kit shows the wrong image, and google cant find any other instances. Hope its just a file pic. Besides most LSx gaskets are reusable. Only must haves are head gaskets at $45/pr from summit
Another big issues is the fact your block is a 98. The cyl walls do not accept any overbore, you can do a max of .005" hone before it must be sleeved. If the walls are out of round or scored, its cheaper to find a fresh block
italiano67
Dec 11, 2016 09:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
confucius101
Sep 2, 2015 03:34 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
