Speedometer doesnt work
Old Jan 16, 2011 | 02:25 PM
91Camaro_RS's Avatar
so i just put in a 350, its TPI speed density, and i have a new VSS sensor, but the speedo wont work, it did work before the swap when i had a 305 in it, and i was using the same VSS sensor, im using a 305 prom (AXXF) but i used the autoprom to make a 350 TPI chip (AUJP)
everything runs and works fine except the speedometer
anyone have any ideas
thanks in advance!
Old Apr 8, 2012 | 09:49 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: Speedometer doesnt work
have to cut the yellow wire? its been so long since i did this swap
going to the vss box delete the vss box and find the correct wire for vss going into the ecm splice in and volla working speedo
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
