Looking for some eng.building ideas
Old Jan 18, 2011 | 09:27 PM
bofish52's Avatar
Long time SBC builder but not for a few years. Looking for some ideas. Feel this is the site to get it.
Have 62 ****** 4x4 wagon with late 80's 350 GM crate motor with about 50,000 mile on it and going to rebuild.
Would like to get close to 400 hp. Have a set of 87 Vette aluminum head with 194 valves. and 88 TPI. Going to stay with the stock runners for the torque I think. This will bolt to a 700r to 411 gears on 33 inche tires. Any and all ideas welcome. THX
Old Jan 18, 2011 | 09:42 PM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
Re: Looking for some eng.building ideas
id go with a 383 if youve got the 350 block, although im sure you could acheive the 400hp from the 350 block, i dont understand what your asking here? if you want to keep that current block or get a new one..?
Old Jan 18, 2011 | 09:45 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Going to be tough, without more info assume that is a low compression crate motor, heads unfortunately arent condusive to making power.
Being as its a TPI just build it for torque youll be a lot happier especially in a vehicle that will want it. Stroke that sucker!
Old Jan 18, 2011 | 10:37 PM
bofish52's Avatar
Looking to keep 350 block and go .030 over. 9.5 comp. Looking for ideas on pistons, cam, valve springs, quinch etc. Planning on roller rockers. and a gear drive timing set. Ideas on injector size.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
