help with picking a cam for my vortec headed l98 350!!
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
need help with picking a cam for my vortec headed l98 350. i would like to for it to pull good from low end to top end an pull hard. An lope pretty good an have lots of power, with some what good street ability.. the vortec head valve gide's have NOT been cut inty.. what do you guys that i should put in it??
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help with picking a cam for my vortec headed l98 350!!
Although you're limited in the lift with the stock Vortecs, there are several cam lobe profiles with lifts less than .480" yet have fairly healthy duration figures.
Download a copy of Comp Cams Master Lobe Profile catalouge. You can see what's out there.
Remember to match the cam duration values with the engines SCR to get the best results.
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
Car: 85 TA (sold), 88 Corvette, 02 Monte
The 91 block so a roller?
Yes you're limited to about 480 lift, and around there you'll want to carefully measure every valve. Biggest cam I could use with mine was about 470 and that was with half the recommended safety margin.
Vortecs like a split with more timing for exhaust than intake.
I'm looking through the comp cams camquest program, and it seems like all the cams that would even work are in their xtreme 4x4 series.
The only xtreme energy one that could fit your 480 limit is the smallest one, with an rpm range of only 600-4600 and only 200 duration. No lope there.
Theres a 4x4 one with 210/214 .50 duration, one with 220/224, and one with 230/234, all with .474 lift which should be safe. I'm kind of guessing they're made with vortecs in mind with the lifts being like that.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
