fuel tank sending unit plug won't come out?
Old Jan 21, 2011 | 11:57 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I am swapping out my fuel pump, and cannot figure out how to get the sending unit electrical connector off so I can pull it out all the way, there is the white horseshoe shaped one and a little black ground wire attached at the top. Or do they even disconnect, as in just pull it and set it there on its side still attached or what?
Old Jan 22, 2011 | 09:50 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Re: fuel tank sending unit plug won't come out?
Look some similar connector images in articles sold in ebay. It can help with any idea.
Denis V.
Old Jan 22, 2011 | 09:59 AM
Engine: 3.8, 3.4
I found out that it unplugged at the body instead of at the sending unit, cut the wires instead, would rather have spliced wires than a bigger hole in the body...
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
