Running 3.4 injectors in 3.1 engine without mods. It's possible?. Please help
Old Jan 22, 2011 | 09:39 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
I must replace injectors in my wife's 1997 GM v6 3100 FWD OBD II.
I can buy 6 cheap new ACDelco 3.4 injectors for the same car with 3.4 engine (3.1 are not available).
But I can't reprogram its OBD II ECM.
My questions are:
1.- They will fit in 3.1 engine holes/connectors?
2.- It will be the air/fuel mixture automatically compensated by ECM?
3.- How about the emissions test (my big dude)? (HC, CO, NOX)?.
Any help will be apreciated, because today I'm in low $$$$$
Thanks in advance,
Denis V.
Old Jan 22, 2011 | 07:45 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Running 3.4 injectors in 3.1 engine without mods. It's possible?. Please help
1) Nearly all GM engines used the same EV1 injector connectors. Most likely the will fit fine and run. You will have issues running excessively rich because the ECM isnt tuned for the larger injectors. This will throw your emissions testing for a loop and risk washing the cyl walls down with prolonged use
2) To a very small degree, but most likely not enough
3) Guaranteed fail with excessive rich condition
Try a junkyard or ebay for a cheap solution. Several companies and sponsors offer injector services which would be more cost effective than buying new
This is not 3rd gen related and needs to be locked, sorry
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
