601 heads on 350sbc need some advice
Old Jan 28, 2011 | 08:09 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I've got 305 heads (601 casting #) on a pre 1980 350 sbc with dished pistons. Everything else on the engine is stock.After I got done adjusting the valve train, I wasn't sure where to leave the timing mark on the balancer at? should I just leave it at 0 degrees and install the distributor? or should I put it a little before 0 degrees since it will be higher compression? Sorry I don't know much about ignition timing and this is my first time.
Old Jan 28, 2011 | 08:17 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: 601 heads on 350sbc need some advice
Leave it at zero.
Old Jan 28, 2011 | 08:28 PM
0pyders's Avatar
Thanks for the info.
What about when I'm about to start the engine, should I retard the timing a bit or just leave that alone too?
Old Jan 28, 2011 | 08:50 PM
Engine: 355
Once the engine fires you will need to set intial timmimg.
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
