Replaced hatch parts... HELP!
Old Feb 1, 2011 | 01:43 PM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
So i replaces my gear nut and guides with a GM gear nut and TDS guides, put it all back together and when I closed the hatch it latched, but the motor did nothing.
Now i cant even get it open!
It's at the halfway position where youre just waiting for it to pull down.
I know for a fact that the motor was working when I took it out.. Turning the key does nothing as far as releasing the hatch either.
I need fast help! How do I fix this!?
Old Feb 2, 2011 | 03:16 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Replaced hatch parts... HELP!
Turning the key should unlock it. If not then its possible that the cable from the lock cylinder to the latch is poo-poo.
There is also a switch on the latch. When you shut the hatch it hits the switch and says "PULL ME DOWN".... to the paradise city where the ham is free and a girls got big ti........oops
Old Feb 2, 2011 | 12:09 PM
nezzie09's Avatar
Engine: 2.8 MPFI
Lol thanks for the reply, after messin with it for a while I figured it out, for some reason that switch wasn't hit and pushing the hatch a little didn't do anything, crawling in the trunk from backseat is no easy task in these cars but i managed, fixed everything and it works great now.
Old Feb 2, 2011 | 03:03 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
When the hatch moves the wires move on that switch and may eventually break. I had that happen to me while the latch was down! You're not gonna shut the hatch when the motor is down!
Old Feb 2, 2011 | 04:01 PM
nezzie09's Avatar
Engine: 2.8 MPFI
Oh, mine latched, but then stayed up and wouldn't unlatch or pull down.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
