Poured fuel injector cleaner down Carb throat
Old Feb 2, 2011 | 07:24 PM
84CAMARO28inFL's Avatar
Is this bad? I saw smoke and treated it as i would a "Seafoam" treatment
now the EGR valve is lean off and the brass fitting that attached it to the pipe came with it, but i cleaned out the carb was the intent.
I used two bottles over a few hours and car has sat for a few days
any danger, harm, or potential bad in what i did? Engine runs strong
Old Feb 2, 2011 | 07:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Poured fuel injector cleaner down Carb throat
I don't understand what you did. You poured Seafoam into the carb while the engine was running? That's fine.
Old Feb 2, 2011 | 08:26 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I've done it many times, and nothing like that happened. I would guess your EGR has seen better days.
bryan623
Mar 22, 2021 06:43 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
