Intake gasket question
Old Feb 3, 2011 | 05:03 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I have dart pro 1 aluminum heads and a Edelebrock high flow TPI base (also aluminum). Im having a hard time deciding what the best intake gaskets are for this application. The closest sizewise seems to be a the felpro 1204s but those i guess are not good for aluminum? Here are the sizes im dealing with and maybe someone else will have a better answer for me.
Head ports
2 1/16" x 1 3/16
Intake ports
1 15/16" x 1 3/16
Old Feb 3, 2011 | 05:56 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Intake gasket question
Hmm. Felpro are all I use. Especially on high performance applications, which tend to be aluminum. Sounds like the 1204 is right for your port size. Be sure to seal the coolant passages with permatex ultra black on both the head and the manifold. Also, use "The Right Stuff" on the end seals.
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
