surging at steady speed, why??
Old Feb 5, 2011 | 12:52 PM
ws6pack's Avatar
Car: 1986 Trans Am
Transmission: auto
Axle/Gears: 2.77
Hey all, I was wandering why my T/A with a TPI 305 is surging at hwy speeds. seems to run fine around town. I have changed the o2 senser, TPS, MTS, cap & rotor, plugs & wires, and cleaned egr valve. the plugs where nice and clean when i changed them so its not running rich or burning oil. the car has gutted cat and looks like oversize 2 into 1 ex. pipe. i have had the car for only a couple of weeks now. I dont have any exp. with TPI so I am a little lost on figuring this out so any help will be greatly appriciated ( where is spell check ) LOL
Old Feb 5, 2011 | 04:05 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: surging at steady speed, why??
replace your fuel filter, if problem persist check fuel pressure. A surge usually means a lean condition.
Old Feb 5, 2011 | 11:55 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Surge at cruise can also be caused by clogged purge canister.
Old Feb 6, 2011 | 08:02 AM
ws6pack's Avatar
Car: 1986 Trans Am
Transmission: auto
Axle/Gears: 2.77
thanks for the replys, I will change the fuel filter and check the pressure and check out the purge canister
Old Feb 6, 2011 | 10:39 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Datalogging is a good place to start.
Ditto on keeping and eye on the fuel pressure.
Plugging off the vacuum port for the canister is a quick way to test that.
Old Feb 6, 2011 | 10:24 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
A batter way to eliminate the canister as the cause of surging is to loosen the gas cap and test drive for comparison.
Old Mar 1, 2011 | 04:58 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
not looking to jump into anyones post but I'm having suring at idle and intermittent lean at idle, I have my canister eliminated and the metal line that goes to the gas tank is open. Could this cause a problem with my idle? I wil put a vacum cap over it and see if the idle changes.
https://www.thirdgen.org/forums/tpi/...e-surging.html
skinny z
Carburetors
Sep 29, 2015 11:25 PM
RedLeader289
Sep 23, 2015 06:50 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
