budget build plans?
Old Feb 6, 2011 | 10:00 AM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
budget build plans?
Not sure if this is the right place for the topic, if I am mistaken please move to a more appropriate section, thanks.
Ok guys I'm finally getting everything together and finishing planning my budget build. I'm shooting for around a $5-6000 budget, the car will be a daily driver as well as used for Auto-X(drifting) so the setup will be setup around this. The car currently is a 90RS w/ a 305 TBI and 700R4, and a Flomaster cat-back. I'd like suggestions for the build that will coincide with what I'm planning.
First off my suspensions setup, I'm going with this entire setup LINK mostly and this is somewhat of a drag setup but the fact that most items are adjustable so I'll be able to set the car for the style of racing and Ill be going with a different coil-over set. This setup comes to around $3769.95 (before tax). On another note they don't change their rear shocks, I've recently replaced mine so they should be fine.
I also want to go with an LS1 rear w/o TCS and a 3.73 gear, I'll be re-doing all brake lines, and fuel lines. Now if I get this rear is it a plug and play deal or will I need to update other parts?
I'll be switching out the 700R4 for a T56, also what do I need besides the trans for that swap specifically? As for the engine I'll need to shoot for torque on this car so I wasn't completely sure what to drop in, what I was debating was either a 350 TPI (around $2200ish) or a LT1 (i've been told $4000+?) but I think the LT1 will run the build too high, any suggestions for the motor setup? Also unsure of an exhaust setup, but it'll probably have cut-outs
P.S. if your not going to post something helpful please don't spam, thanks.
Tim
J-money
Jan 4, 2019 09:45 AM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Jorlain
Oct 8, 2015 01:57 AM
fasteddi
Sep 10, 2015 09:32 AM
