stuck rpm gauge??????
Old Feb 6, 2011 | 02:57 PM
GREEK BANDIT's Avatar
Car: camaro iroc-z
Engine: 5.0
i just installed a new stereo in my car and today i noticed that my rpm gauge is stuck at 7000 rpm i started the car and it still stayed there. i didn't get a chance to drive it because its stored for the winter but could my stereo have anything to do with it? the battery also died and i charged it as i was installing the stereo but i don't see how that could affect anything. anyways if anyone knows wtf is going on any help would be appreciated.
Old Feb 7, 2011 | 08:38 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Somebody Put A Tack In The Tach Pointer
If the pointer doesn’t move at all when turning the key on and off check for a mechanically stuck pointer.
If it does move there is circuitry in the dash near the tach which goes bad.
It’s contained on a small plug-in PCB or integrated in the main board.
On or near the PCB you’ll see a capacitor, replace it.
Also on the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
Jote4805
Aug 25, 2015 06:11 PM
