my new damper doesnt wanna go all the way on
Old Feb 7, 2011 | 10:50 AM
tjtaylor's Avatar
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
ok i have a 1973 sbc 400 and im trying to put my new harmonic dampner on and it wont go on all the way. it needs to be about another rib and a half over so the belt lines up right. whats wrong. i have baked the thing to 450 degrees for an hour and used refrigernat to cool the crank to make it colder. and it still wont go on.. and it is the right balancer and the crank is clean and the keys arent smashed here is the link of the balancer http://www.summitracing.com/parts/SUM-C4266/ helllp
Old Feb 7, 2011 | 10:58 AM
whiteboycv67's Avatar
Car: 90 Firebid
Engine: 3.1
Axle/Gears: 10 bolt posi w/4.11s
Re: my new damper doesnt wanna go all the way on
put the bolt in the end of it and run it down with an impact grease crank first and put a dab of rtv in keyway at the back it will leak small amount of oil in time without the rtv
Old Feb 7, 2011 | 11:04 AM
Car: 90 Firebid
Engine: 3.1
i take that back its the wrong one heres link for right one http://www.summitracing.com/parts/SUM-161350/
Old Feb 7, 2011 | 11:40 AM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
no thats no it and plus the threads on the crank look to weak to impact the thing on. and thats not the right part. sbc 400's are externally balanced so thaqt wont work at all and its not sfi approved.. come on i need the motor in tonight need some educated answers here!!!!
Old Feb 7, 2011 | 06:08 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Yeah I think he missed the "its a 400" part. And yes trying to crank it on with the usual bolt is a bad idea and would probably strip your threads since it wouldnt even have half the threads engaged.
What method are you using to install it? Heat and hammer? Have you tried the actual installation tool (rent one from any chain auto parts store)? Basically it seats a bolt all the way into the crank (engages every thread and doesnt turn so unlikely to strip) then theres a huge nut you turn with a giant wrench.
Old Feb 7, 2011 | 11:09 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
ha i think so, and yeah i went out tonight and got a trick flow balancer sfi apporved 18.1 and heated it up used the dead blow a couple times then gave in and bought the install tool kit too. it worked beautifully. i will be installing the motor either tommorow or wednesday now
Old Feb 7, 2011 | 11:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why does this thread look so familiar?
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
Tylermcclinton
Sep 17, 2015 07:50 PM
MoJoe
Sep 15, 2015 12:50 AM
Veaceonee
South West Region
Sep 6, 2015 10:04 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
