BACKFIRING FROM BOTH ENDS
Old Feb 8, 2011 | 08:20 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I have an '84 Z28 that will backfire (in the carbuerator) upon deceleration. However, when I drive to work (or Home) and turn off the car; BOOM!!!!!!!! It sounds like a shotgun. This backfire is in the rear. The carb backfires are most likely due to the carb needing a good rebuild. The backfire from the rear is so loud, that I am worried about serious damage if it is not addressed. I am planning on replacing the ENTIRE EXHAUST SYSTEM, but could it be something else?
I love my car and it turns heads on the street, but if I park next to you, hold on to your hat. Every Saturday I wake up my neighbors with another backfire. I have adjusted the air/fuel ratio, changed the plug wires, adjusted timing already. I will check for a gasket leak. I would think it may be in the header gasket. Any other places I should check?
morrow
Jan 13, 2024 12:29 PM
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
