engine temp sensor questions
Old Feb 8, 2011 | 05:33 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
hey guy, gauge isnt working so i found a sensor, driver side on the 305tpi engine, up front in the middle of the front 2 spark plugs, which i believe is the temp sender, however the one in there doesnt have the 1 pin male end like the new one does. i cant visually see it, but seems to be more of a circle end with no where for the plug in. that the right one?
Old Feb 8, 2011 | 05:48 PM
Re: engine temp sensor questions
Those are a sort of "mushroom" connector, that goes on from the side. Your car's wiring should have the right plug for it (did at one time).
Old Feb 8, 2011 | 06:00 PM
jeff_blake's Avatar
ya it has a mushroom, but the adapter is a 1 pin, as well as the new sensor
Old Feb 8, 2011 | 06:04 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
T.P.I is out of my jurisdiction, but mine on my 91' 305TBI is on the pass. side and the O2 sensor is on the drivers side....... Is the sensor you see in the block?
Old Feb 8, 2011 | 06:20 PM
jeff_blake's Avatar
yea
Old Feb 8, 2011 | 06:29 PM
Pull it out and if coolant falls on your face you got it..... That's how I learned........
Old Feb 8, 2011 | 07:52 PM
jeff_blake's Avatar
ok that was in fact the problem, gauge works.. but u have tap it.. lol
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
