355 build questions
Old Feb 9, 2011 | 07:48 PM
88camaroman's Avatar
Car: 82 camaro sport
Engine: none yet
Transmission: none yet
Axle/Gears: 9in ford no center section yet
355 build questions
Ok guys im going to build a 355 real soon. I have a 350 block out of a 72 camaro im going to use. Bore it out .30 over with 9 to 1's. I plain on using 2.02 double hump heads. The question I got is what cam should i get. I dont want to get to big of a cam because I was told if i get to big of one It will need new rocker arm studs. Because of the cam having to big of a lift. Is this true? If so what cam do i go with that way i wont have to have extensive head work. Also if this helps I am going to use a holley high rise intake and a 650 holley carb. Thanks guys
Old Feb 9, 2011 | 09:57 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: 355 build questions
.030 over 350 with good heads will be a good performer. I suggest vortec heads instead of double humps. I built a 350 with .030 over 2256 flat tops, vortec heads, and a Erson E110030 cam made 375 hp and over flabs of torque. Cam specs are 218 duration@.050458 lift. idles smooth.
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
