87 gta runs great without MAF power
Old Feb 12, 2011 | 03:50 PM
my87_5spgta's Avatar
i have been having a problem with my 87 gta.I have a 87 trans am project car where i use the relays from my gta to solve a problem on the TA. fixed the TA.I put the relays back on my GTA Now i have a problem with gta..ughh! The GTA now has a mis and stumble off the top of throttle.I unpluged the maf power relay and that mis stumble goes away,but i have a service engine light. when i plug the relay back in the mis and stumble are back but NO engine light..I just replaced the MAf power relay thinking that was the problem.
Old Feb 12, 2011 | 06:43 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: 87 gta runs great without MAF power
MAF is bad, replace it with a new one.
Old Feb 12, 2011 | 07:28 PM
Stephen's Avatar
Car: 87 GTA
Seriously doubtful that a MAF will suddenly go bad, just sitting & not doing anything.
Double check which relay you used for each plug. 2 of the plugs are the same & the relays appear to be the same, but 1 has an extra "circuit" inside it, yet the plugs will plug into either one.
You could try swapping those 2 plugs & I bet it'll be alive again.
Old Feb 13, 2011 | 02:08 PM
I went back a forth checking part numbers on here matching them to relays.So as far as i know its all matched rt. Now today when i went to the start it up with the maf power still unplugged it ran the same as it did when i had it pluged in.It only started to run better as it warmed up?
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
Bradsaundry
Aug 12, 2015 12:34 AM
