Distributor HEI Drive Gear question
Old Feb 17, 2011 | 10:53 AM
JP007's Avatar
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
I will be converting my 5 speed 91 RS to Carb and being as these cars have roller cams I think I need to remove the distributor drive gear from existing distributor and put it on the HEI I plan on installing. Can someone please confirm? Getting conflicting data.
Thanks,
JP
Old Feb 17, 2011 | 11:02 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Distributor HEI Drive Gear question
Not that I ever heard of.
Old Feb 17, 2011 | 11:04 AM
Car: 1992 RS
Engine: Carbed 350
Why swapping to carb? You'll not gain any performance and loose gas mileage.
Old Feb 17, 2011 | 11:11 AM
JP007's Avatar
Car: 89 Formula
Going to a 4:10 gear with posi so mileage is not factor and I like the sound of 4 barrel carb. Already have a stock TBI 305 Formula and stock TPI 350 Formula and this one a play toy. Already got headers, and 3" exhaust coming and just want to use up the 305 until I get the 400 sbc ready for install.
Any thoughts on these Ebay HEI aftermarket distributors for $50? I really like original GM HEI first.
Old Feb 17, 2011 | 11:25 AM
Car: 1992 RS
Engine: Carbed 350
Not sure about a $50 ebay dizzy. Just about every auto parts store carries Accel dizzy on the shelf for $125 or less - and no shipping, no hassle returns, no waiting.
Old Feb 17, 2011 | 11:50 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I know for different type of cams there are different distributor gears (the metal differs with different cams). But I'm not sure what goes with what tho.. :S
Old Feb 17, 2011 | 06:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I would use the gear that goes with the cam
http://www.camaros.net/forums/showpo...64&postcount=5
Old Feb 17, 2011 | 06:59 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I bought a mallory for my flat tappet cam, and I'm not sure but I think it comes with the right gear already on it..
Just watch out that you get the ground wire under the screw, I already burnt a hole in my coil cap.
Old Feb 17, 2011 | 08:15 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Flat tappet cams don't need the special melonized gear
Old Feb 17, 2011 | 11:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Billet roller cams need a bronze gear. Factory roller cams are still only cast cams so a normal distributor gear will work.
There are different sized shafts for different distributors. 0.500" and 0.491". If you're going to swap the gears, make sure you have the proper sized gear.
Old Feb 18, 2011 | 07:14 AM
JP007's Avatar
Car: 89 Formula
AlkyIROC That cleared this up. Very much appreciated. A basic GM HEI will be fine. Thanks!
JP
Old Feb 18, 2011 | 11:43 AM
Car: 1992 RS
Engine: Carbed 350
OK - so is it the gear that's grinding away at the cam, or the cam grinding away at the gear?
Old Feb 18, 2011 | 06:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The camshaft drives the distributor and oil pump. Bronze gears are softer than the steel cam and are designed to wear out. The cost of a gear is much less than the cost of a camshaft. The camshaft in my car is $400. I wouldn't be too happy if the drive gear on the cam wore out because of a hard metal distributor gear.
There are some billet roller cams with a different drive gear pressed onto them to use a normal distributor gear.
Old Feb 18, 2011 | 08:35 PM
If one does not know what type of cam he has (i bought the car like this) then which distributor gear would you recommend? Steel? Bronze? Melanite? Thnx!
Old Feb 19, 2011 | 06:32 PM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
I disagree with this statement, not all factory roller cams are cast. The stock cam I took out of my 92 LB9 was definitely billet and thus would have used the mellonized gear.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 7, 2015 04:49 AM
