quick noob question
Old Feb 19, 2011 | 03:24 PM
jollythought's Avatar
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
quick noob question
I know this question is pretty basic, but I want to make sure I understand completely. I am trying to diagnose my fuel pump so I was going to check the voltage on terminal G on the aldl. If there is voltage then the fuel pump is faulty? And if there is no voltage then there is a problem with the circuit? Can I just use a voltmeter to check the voltage?
Old Feb 19, 2011 | 04:12 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: quick noob question
You will need to check the fuel pressure on the return line. SHould be around 12 psi.
Old Feb 20, 2011 | 02:22 PM
Car: 1983 Trans Am
Engine: Lu5
ok thank you
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
