85 z28 got a miss
Old Feb 22, 2011 | 04:26 PM
jrfan4ever's Avatar
85 z28 got a miss
i have a 85 z28 305 tpi and it has a miss i have done a complet tune uo and still has a miss it idles fine but when u give it gas here comes the miss thank for any help
Old Feb 24, 2011 | 11:11 AM
84Recarotrans's Avatar
Car: 1984 pontiac trans am Recaro
Engine: 305 HO L69
Transmission: 5 speed
Axle/Gears: 10 bolt, 373, disc rear
Re: 85 z28 got a miss
Start small, check all your electronics, TPS, MAP, Idle Air Control,etc. Make sure there all plugged in good and that there isnt any oxidizing on the plugs of the sensors, then check for cracked or broken vacuum lines, check timing, have you ran some injector cleaner to see if you have a sticky fuel injector? thats the stuff i would start with, mainly because it aint gonna cost much to do so.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
devilschariot
Feb 25, 2016 03:08 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
Ranbo108
Sep 9, 2015 12:20 PM
