Roller rockers
Old Feb 23, 2011 | 08:51 AM
91fbGladback's Avatar
Roller rockers
I'm assembling my heads and I don't know what ratio roller rockers I should use for my application.
355 , rebuilt stock internal
200 cc world products sportsman ii with 64 cc chambers
Valve train bought as a kit with cam, Manley race valves(donated)
Comp cams extreme energy cam 224/230 @.050 112 l s
Holley stealth ram w/ 58mm throttle body
42 lb injectors (if the guy can tune it)
Hooker headers 2055s
Ran on a 91 map system
Old Feb 23, 2011 | 09:35 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Roller rockers
1.5 is the standard ratio unless your cam card indicates the use of 1.6. You could check with Comp cams. Go to their web site. There's a toll free help number you can call.
Old Feb 23, 2011 | 10:15 AM
MustangTamer's Avatar
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
Re: Roller rockers
i have the same heads as you and it says that you cannot run 1.6 roller rockers without longer pushrods.
run 1.5s and tell me how it runs im doing a build pretty much with the exact same stuff as you with just a little less cam
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
