crank no start???
Old Feb 26, 2011 | 12:10 PM
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
crank no start???
hey i did a heads cam intake swap on my 88 gta 5.7, i got the 30lb injectors n a chip burnt for it. it was running fine yesterday n then i hooked up a fuel pressure gauge to it noticed it was at 30 psi so i put it back up to the 43 psi spec. but once it went to 43 the needle started bouncing a little bit between 42-45 psi. started having a harder time starting after that, now today it just wont start, any ideas on wat to check or anything?
Old Feb 26, 2011 | 08:38 PM
rodrigo92rs's Avatar
Re: crank no start???
the pressure might be too high. to much pressure = no start. try lowering the psi
Old Feb 26, 2011 | 09:15 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Doesn't sound like your guage is working correctly. Those injectors sound a bit large too. I actually lowered my fuel pressure when i installed my 24 lb injectors. Try a different guage and try lowering your fuel pressure to stock.
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Tonyy_z
Aug 12, 2015 07:20 AM
