TBI Trouble. I NEED HELP!!!
Old Mar 2, 2011 | 11:23 PM
mrfilth1984's Avatar
Car: 1988 Chevy Camaro Sport Coupe
Engine: LO3 V8 5.0 (305)
Transmission: M5
Alrite well my car seams 2 run perfect at times then the car starts pulling it self l so I open the hood and look around then decide to take air cleaner off and realize that the gad cuts off at the tbi and then turns back on tthen it does it agaun. I alrwady put a lot of money with these so called mechanics fuel pump filter tbi and all that already replaced a friend of mine said it might be the " computer " in the car because that's the only thing controling the tbi injectors.pleeeease help me I'm so frusteated. That I can't get a straight answer.
Old Mar 3, 2011 | 08:56 AM
dualdj1's Avatar
Car: 98 Chevy Cavalier
Re: TBI Trouble. I NEED HELP!!!
I'd like to try and help you, but I don't understand the problem. I don't know what this means:
"realize that the gad cuts off at the tbi and then turns back on tthen it does it agaun"
Can you please give more detail? Break apart points of exactly what's happening and when it's happening, throttle conditions, idle, hot/cold, etc? With electronics you need to provide as much detail as possible, as clearly as possible to correctly diagnose the problem.
Old Mar 3, 2011 | 11:06 AM
Transmission: M5
Well it seams to only happen wen the car is warm because in the mornings it runs like a champ
The car will be on and the gas cuts off and then goes back on its seams too be electbrical. It happens while idle ruunning at all times this happens
Old Mar 3, 2011 | 11:18 AM
dualdj1's Avatar
Here's what you need to do. Check your fuel pressure. Get a gauge/testing kit somewhere (i think you can get a loaner at autozone), and see if you're holding good fuel pressure when it's acting up. I'd also suggest trying some injector cleaner as well.
2nd, reseat your harness connections on your distributor. Bad connections here can cause it to not spray (had this problem on my van).
Reply back with the results of your pressure test.
Usually a computer won't go intermittent like that. You could have an oil pressure sensor going bad as well. Must have a good oil pressure reading for your fuel pump to run, it's just a safety mechanism they put in. If you are dropping fuel pressure, and know your pump is good and filter clean, then that's something to check.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
