ticking sound
Old Mar 3, 2011 | 04:15 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
ticking sound
91 camaro rs v6
the car has a ticking sound...i know it could be a exhaust leak..and been told possible rocker floatin around..maybe??..how do i check for an exhaust leak?? or the rocker? or could there be anything else?
Old Mar 3, 2011 | 04:27 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: ticking sound
do you hear the ticking sound at idle? does it get louder and quicker as the RPMs rise?
for an exhaust leak it could be the manifold/header gaskets. i had it happen on my 00 and it was annoying/sounded terrible.
to check for that look around the manifolds/headers and see if you see any burn/scorch marks.
it could be a rocker or lifter. just take the valve covers off and check each rocker, you'll know if one is loose.
for a lifter, take a longer screwdriver or if you're fancy enough one of those stethascopes. listen around and if you hear it from the top end it could be a lifter, or a push rod.
for pushrods go back to the rockers and take them off, and pull out each rod and check if any are bent.
Old Mar 3, 2011 | 06:23 PM
torque_is_good's Avatar
Re: ticking sound
test for exhaust leak around manifold or header: you will need one person to assist. First, borrow a cigarette from someone. At $5-$6 per pack why buy a pack. Then, with the engine OFF, lightly blow smoke around the header or manifold and watch the behavior. Do that on both sides. THen, ask the helper to start the engine and put it at about 1500 rpm's or so, again, lightly blow smoke but pay close attention. Do you see any of the smoke being diverted? If so, you have and found a leak.
Old Mar 3, 2011 | 06:33 PM
Convoy25's Avatar
Re: ticking sound
wow thats a pretty genius idea
Old Mar 3, 2011 | 08:02 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
Re: ticking sound
ya i hear it at idle a low ticking and then it does get louder as the rpms climb.
Old Mar 3, 2011 | 08:11 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Re: ticking sound
wow that is clever Torque. haha nice! Its the simple things that are cheap if not free to do that people like (me) would never think of
Old Mar 4, 2011 | 07:32 AM
Re: ticking sound
thank you, but at $6 per pack, and the fact that I don't smoke, why would I waste $6 for one cigarette????
seriously, you pick up a lot of tips from old timers over the years. It is then our duty to continue to pass them down to you young uns so you can continue the flow of data
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
