406 budget rotating assembly
Old Mar 8, 2011 | 04:57 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
So...I want to upgrade my stock 406 rotating assembly...but don't need 600hp type parts. My goals are 500 hp, about 6500 rpm (MAX) and NA (no nitrous either)
Is this a decent deal?
http://www.competitionproducts.com/S...ctinfo/SS406F/
Old Mar 8, 2011 | 11:00 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 406 budget rotating assembly
Not a terrible price, how much for shipping? If you're going to run it to 6,500, I recommend you price the balancing service too. Also, I would never swap rotating assy without fully preparing the block. Line hone, check deck alignment, bore and hone with torque plates, and clearance the rotaing assy in the block.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Dragonsys
Sep 25, 2015 03:51 PM
