Mix n Match Question: Block, Heads, TPI
Old Mar 9, 2011 | 09:03 AM
WhoCares?'s Avatar
1971 chevelle 350 block
New AFR 195cc straight plug heads
87-92 TPI manifold
Is this configuration possible to bolt up?
As of right now i know the intake manifold wont bolt up to the current heads on the engine i could only use a 85 TPI. I've never dealt with AFR heads before and dont know what their bolt configuration is. Any help would be great.
Old Mar 9, 2011 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
AFR only uses straight 90 degree intake bolts to the best of my knowledge. They may make '87-up heads, but I'll let you do that research.
195cc heads and factory TPI base is about as mis-matched as you could get, though. Low-RPM induction and high-RPM heads.
evilstuie
Jan 9, 2020 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
anesthes
Aug 8, 2015 09:37 PM
