Moving a car with the torque arm out...
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I have the engine, trans, driveshaft and torque arm out of my 'vert. Of course, now is when the muffler falls off of my daughter's car. Can I push it, by hand, out of the garage and down the driveway and then back in without seriously damaging anything on the rear suspension/axle? I'd really prefer to fix my kid's car in the garage/on the lift than lay out in the driveway. I'm getting too old/fat/lazy for jackstands.
Re: Moving a car with the torque arm out...
It'll be fine, I moved mine a lot with the engine/tranny and tq arm missing
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
I drove my up my driveway with the torque arm out, got on it for a second without thinking... bad idea; the torque arm didn't line back up but I made it fit with a BFH.
Transmission: 4L80E/4L80E
Just don't try to stop it using the parking brake. Axle housing twist will be resisted only by the shocks.
Car: 92 T/A 'vert
OK Thanks!
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Could always cut out the floor pan and Fred Flinstone it! Just messing with you man, It shouldn't hurt anything.
Car: 92 T/A 'vert
Shoemaker but I think it will help:
AkDrifted
Aug 17, 2015 07:45 PM
