Ive done my best to avoid asking for help. Need a few pointers now
Old Mar 17, 2011 | 06:26 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
K guys, 82 trans am i bought awhile back,
It idles at around 800-900 but will eventually stall if left running. While at idle if i give it gas it hesitates and then will rev.
The REAL PROBLEM is that it blows BLUE smoke, it keeps fouling plugs oily black, and since im running open headers its shooting black muck on my garage floor
had a old 305 in it. I bought a running driving camaro with a good solid 350 700r4 and swapped it in. The motor i swapped in ran PERFECT when i pulled it from the other car no smoke at all. I bought a weiand intake and holley 600 carb with manual choke. msd HEI dizzy.
My initial timing is about spot on, #1 was verified tdc with a coat hanger, and the rotor was pointed right on the 1st plug wire. So it is on time. i have a craftsmen pro timing light but still havnt figured out how to use it as it only flashes white line instead of a solid red line like im used to.
Thanks Joshua,
Old Mar 17, 2011 | 09:46 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: Ive done my best to avoid asking for help. Need a few pointers now
black plugs if it smells like gas then its running to rich.
Old Mar 17, 2011 | 10:03 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
blue smoke is oil though. just from what you put in the first post, i'd look at the intake gaskets. as for the craftsman timing light i have one too, the only way i can see the mark was to put white out on the tdc hash mark.
Old Mar 18, 2011 | 12:07 AM
intake gaskets are new, and i installed them, i could have f'd it up though so ill redo it tomorrow. Thanks, Joshua
Old Apr 8, 2011 | 07:41 PM
Heres what it was, intake gaskets didnt seal, due to the weiand intake i was using is some kind of screwd up. Got a new dual plane intake, she runs great
Old Apr 8, 2011 | 10:44 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
glad you got'er done
2012sergen11
Oct 13, 2015 07:38 PM
LittleFranks
Oct 7, 2015 11:26 PM
Numbah-1
Oct 2, 2015 08:27 AM
project89
Sep 22, 2015 09:35 PM
Magman
Sep 13, 2015 12:14 AM
